New Topology with 10.1 Issues
1560
6
06-26-2012 11:37 AM
TedCronin
When creating a new topology with 10.1 on a 10.0 SDE Geodatabase, I can no longer access with a 10.0 Desktop client.
AndrewMoffitt
I suspect that the new topology automatically "upgraded" your SDE DB to 10.1.  Check this in ArcCatalog via properties.
TedCronin
Upgrade Status...  This geodatabase matches the ArcGIS release you are currently using, however, database internals such as stored procedures can be upgraded.  I saw this through beta...  See this from 10.1 Client.
From 10.0 Client. The 10.0 database matches the ArcGIS release you are currently using.
So, it matches 10.
This is my Test Server, btw, before I do my upgrade in a few hours.
Was able to change topology cluster with no issue yesterday.
CraigGillgrass
Ted,
What version of 10.0 with Service Pack are you using?
thanks,
TedCronin
SDE is at 10 SP3.
CraigGillgrass
Ted, can you supply the schema of the Topology you created at 10.1 so that I can recreate it here?
I'm not able to reproduce the issue that you're reporting.
thanks,
TedCronin
I updated the database schema and installed 10.1 SDE, so there is no issue.  In process of upgrading all desktops to 10.1 as well.  2 left.
