Registering Spatial View
4233
5
07-09-2012 07:49 PM
ShaunWeston
I'm having trouble registering a spatial view. I have setup a view in SQL Server between a feature class and a business table, so I have a view in SQL server showing the feature class joined to the business table and would then like to see this spatially in ArcGIS Desktop. I thought the next step would be to register it using sdelayer -o register command, but just can't get it to work. I've got this:
sdelayer -o register -l gis.View_Sewers,Shape -e l
-t GEOMETRY -C UNITID -D UTILITIES -i sde:sqlserver:GISDEV
-u GISCREATOR -p GISCREATOR
This gives me an error saying  invalid column data type, so I thought this would be pretty basic, but can't seem to get my view to work?
So, UNITID is the main ID in the business table. I noticed that after I make my view in SQL Server, I can see it in ArcCatalog, however it's not registered.
VinceAngelo
Esri Esteemed Contributor
In order to register a spatial view:
1) The geometry column must be a native geometry type (not SDEBINARY/SDELOB)
2) A registered rowid column (NOT NULL, unique, which maps to SE_INT32_TYPE) must exist
3) It must only reference column types supported by ArcSDE, and
4) It must be registered by the owner of the view
Your 'sdelayer' example has several issues:
1) The view owner was not used to register
2) You didn't specify coordinate reference parameters (-R or -x/-G/...)
3) You used the SIMPLE_LINE type for data that may not conform to that more rigorous
standard, and didn't permit multi-part shapes (+)
It would probably be instructive to use 'sdelayer -o stats' on the geometry source table
and 'sdetable -o describe' on the view, to see which "column data type" may be invalid.
- V
VinceAngelo
- V
ShaunWeston
Thanks for the response:
I didn't realise this:
So, if you wanted to create a spatial view between a feature class in SDE BINARY and a business table, how would you do that? would you have to create it through this command "
-o create_view" instead of through SQL server?
VinceAngelo
Yes, that's pretty much why 'sdetable -o create_view' exists ('create_view' only for
SDEBINARY/SDELOB, 'register' only for native). If your view is complex, use phantom
tables of the right column types to create the view, then edit it to point to the
correct tables (with correct SQL).
- V
RobertHu
I wonder why you need to register a SDE spatial view. I use 'sdetable -o create_view' to create SDE spatial views a lot. Never register the views after creation. They seem working fine with ArcGIS (i.e. ArcCatalog, ArcMap, GP tools).
VinceAngelo
It's an either-or situation (create_view populates a row in the layers table if a SE_SHAPE_TYPE
column is present [provided that column is itself registered, otherwise an error]).
- V
