NetCDF with time bands
1321
01-30-2013 05:31 AM
M_J_Glasbergen
I've got a load of netCDF files (example attached) of rainfall radar data. The files are split by date (one file a day). In one file, 24 hourly values per cell are incorporated. Instead of having some kind of time dimension it seems that every time value is in a seperate variable (in this case: band 1 - band 24) and I can't figure out how to create a raster from the netCDF which is time-sensitive, so I can view different time slices by date (instead of selecting a differend band), so I can also create animations with it. The best solution would also have the possibility to merge all seperate files into a single netCDF or raster layer, since I've got an entire year to work with.
