Hi Kory Kramer!
Yes, I am using ArcMap, and I created the shapefile in ArcMap Although I have to access ArcMap through Citrix which is probably where the nightmare starts. There are seven different files for my shapefile. I first tried just opening the mxd that contained the shapefile/data by copying all the related files to Citrix's drive (I can't access my own computer's files through Citrix, and Citrix seems to wipe its drive after each session, so I had to copy my work to Citrix's drive to open them), but then it gives me this red exclamation point of death.
I think school taught me that I just need to reconnect the source to HighStrengthWaste_Points to get it working again, but that didn't work. I got an error -
So instead I tried to just re-add the shapefile which is how I got to the shapefile with no points or attribute table but a separate dbf. A lot of the issue may be with Citrix's drives and being unable to just directly connect to my computer's files. I can't drag anything directly from my computer files into ArcMap while it's being run through Citrix
To be honest, this is what the content looks like in my computer files because of how Citrix was saving it while I was first making it -
It's really confusing having so many versions of the same files instead of having them just replace their older versions.
When I try to open the most recent shapefile HighStrengthWaste_Points (2).shp, I get the error below.
I can add the older versions HighStrengthWaste_Points (1).shp and HighStrengthWaste_Points.shp, but they're empty.
When I add the most recent dbf HighStrengthWaste_Points (6).dbf, it attaches to the (1) shapefile, but there's still no points or attribute table for the shapefile.
Sorry that this got so complex, and thank you so much for replying! Don't stress yourself over my problem, I'll understand if you can't help!
