Layer's don't match / Wrong Projection?
81127
68
05-19-2010 03:29 PM
AnjaWietholter
I have a table with geocoded Lat/Long Values that I want to add as point features to my map. However when I add the table and add X/Y data (Tools-Add X/Y data) the data is added to the map but the projection doesn't match up. I did compare the coordinate systems and they appear to be the same whoever the extent doesn't match up.
My Shapefile with the Lat/Long Points has similar values in projected coordinates compared to the decimal degrees which leads me to believe it doesn't project?
Here is an example. My Zip Code layer in decimal degrees:
West: -117.597982
East: -116.080157
North: 33.511553
South: 32.530161
In projected or local coordinates:
Left: 6150765.000000
Right: 6613436.500000
Top: 2129760.000000
Bottom: 1775304.125000
NAD_1983_StatePlane_California_VI_FIPS_0406_Feet
And my XY layer that doesn't match:
Decimal:
West: -136.179977
East: -136.179964
North: 25.945595
South: 25.945576
Left: -117.388904
Right: -116.371055
Top: 34.517990
Bottom: 32.543795
NAD_1983_StatePlane_California_VI_FIPS_0406 also
I tried about everything. If somebody could help me with this it would be GREATLY appreciated.
Tags (3)
MelitaKennedy
Esri Notable Contributor
The map31 data is in decimal degrees. Use the Define Projection Tool to define the data with the appropriate geographic coordinate system. Then you can use the Project Tool (or ArcMap) to convert it to PSAD56 UTM 17South. It might be in PSAD56 or WGS84.
Melita
MelitaKennedy
We really need an example point from the CSV file, plus a general idea of what location the data represents (county, city, etc).
Melita
MelitaKennedy
Hi Rachael,
The points are in UTM zone 12 North, rather than 13 (very generally: Red Hill area of the county). Try defining the data as NAD 1983 UTM Zone 12N. At that point you can either let ArcMap project it on-the-fly to zone 13, or create a copy via ArcMap (right click in the table of contents, data, export data, choose to export in the data frame's coordinate system) or the Project Tool (once the points are in a shapefile or feature class).
Hope this helps,
Melita
DuartePrata
Hello! I'm a novice in Arcgis and I´m also facing a similar problem... I cant align points created in excel to a map that I already had.
For anyone that can help, here is the info:
Points
Projection: Transverse_Mercator
False_Easting: 200000.000000
False_Northing: 300000.000000
Central_Meridian: -8.131906
Scale_Factor: 1.000000
Latitude_Of_Origin: 39.666667
Linear Unit: Meter (1.000000)
Geographic Coordinate System: GCS_Datum_Lisboa_Hayford
Angular Unit: Degree (0.017453292519943295)
Prime Meridian: Greenwich (0.000000000000000000)
Datum: D_Datum_Lisboa_Hayford
  Spheroid: International_1924
    Semimajor Axis: 6378388.000000000000000000
    Semiminor Axis: 6356911.946127946500000000
    Inverse Flattening: 297.000000000000000000
Extent:
Top:4644500.000000 m
Left:654925.000000 m
Right:720825.000000 m
Bottom:4561986.000000 m
DEM
Extent:
Top:560000 m
Left:263999.999999999 m
Right:375999.999999999 m
Bottom:460000 m
It seems that is the extent that is wrong... How can I correct this?
Thanks in advance!
NeilAyres
Melita,
you must have the patience of Job!
Keep up the good work.
DianneOlson
Oh my gosh I am having this same frustrating problem.  I have points from our vendor and they lay just fine in Google Earth when I import them.  Here are three sets of the Lat/Long.
38.7236133333 -104.6992050000
38.7238900000 -104.6989933333
38.7239366667 -104.6990150000
NAD_1983_StatePlane_Colorado_Central_FIPS_0502_Feet
Projection: Lambert_Conformal_Conic
False_Easting: 3000000.000316
False_Northing: 999999.999996
Central_Meridian: -105.500000
Standard_Parallel_1: 38.450000
Standard_Parallel_2: 39.750000
Latitude_Of_Origin: 37.833333
Linear Unit: Foot_US
GCS_North_American_1983
Datum: D_North_American_1983
When I dump the exact same lat longs into Arcmap, they do not come in correctly.  I see from the extent that these points are
Top: 38.728807 ft
Left: -104.699205 ft
Right: -104.694992 ft
Bottom: 38.722677 ft
My pole point extents are the following:
Top: 29887959.6930 ft
Left: 0.0 Ft
Right 84146321.696 ft
Bottom: 0.0 ft
My light point extents are similar to my pole extents.  In fact all of my data in my master map has similar extents.
Top:  1336807.832 ft
Left 0.0 ft
Right: 3239698.78800 ft
Bottom 0.0 ft.
What in the world is wrong?  Looks like these points are about 658 miles away from one another!
Thanks for any help.  I'm leaving for the bar now!
DianneOlson
Never mind - I figured out how to convert this!
MelitaKennedy
I'm sorry about the delay in responding.
It looks like the first dataset has the wrong coordinate system definition. One thing I look for is what are the extent values? Are they similar to the false easting/false northing values? In this case, the false easting/northing values are 200000.0 and 300000.0, but the Y/northing values are 4.5 million. I think this dataset may be using a UTM zone instead, possibly 29N (N = north).
Melita
NathanBarnett
I'm having a mismatched projection problem as well.  I have a TAZ layer, and 5 polyline files.  The first polyline matches up with the TAZ layer fine.  The other four come from a co-worker and I'm not sure how they were created.
The TAZ layer has the following coordinates:
NAD_1983_Georgia_Statewide_Lambert
WKID: 102604 Authority: ESRI
False_Easting: 0.0
False_Northing: 0.0
Central_Meridian: -83.5
Standard_Parallel_1: 31.41666666666667
Standard_Parallel_2: 34.28333333333333
Latitude_Of_Origin: 0.0
Linear Unit: Foot_US (0.3048006096012192)
Geographic Coordinate System: GCS_North_American_1983
Angular Unit: Degree (0.0174532925199433)
Prime Meridian: Greenwich (0.0)
  Spheroid: GRS_1980
    Semimajor Axis: 6378137.0
    Semiminor Axis: 6356752.314140356
    Inverse Flattening: 298.257222101
and these extents:
Y: 12503462.7160497 to 12694270.8447545 Foot_US
X: -120406.902007222 to 43657.1490820976
The first polyline that lines up well is in GCS NAD83 and has the following coordinates:
WKID: 4269 Authority: EPSG
  Spheroid: GRS_1980
and these extents:
Y: 32.8478994582219 to 32.6640322039645 Degree
X: -83.6616686449638 to -83.615816768027
The first of the other polylines (I believe) originally had no GCS but is now:
  Spheroid: GRS_1980
(which is same as the first polyline that works).
The extents are wildly off from the working polyline:
Y: 3095050.23747941 to 3072264.87089158 Degree
X: 146084.714474299 to 157349.799715325
Usually, I receive files in GCS NAD83 (especially from the Census Bureau's TIGERline set), create polylines in the same set, and project all in a State Plane projection.  I'm not sure in what GCS these polylines were created, and I can't seem to match them up.  I tried changing the GCS to UTM 16 and 17 but were still too far south.
Any help lining these all on top of one another would be highly appreciated!  Thank you in advance.
MelitaKennedy
The TAZ layer (in Georgia statewide Lambert) appears to be around Macon, Bibb County, more or less. The other layers might be in state plane (Georgia East), but the Y values don't match up. I also checked UTM, but that didn't match either.
Melita
