Import ESRI network Dataset into Oracle Spatial Network Model
842
12-10-2011 08:00 PM
GISAnalyst
how can we import ESRI Network dataset model  it into Oracle Spatial network datamodel (they have diffrent models and logic). Is there a tutorial or tool that will accomplish this task? The data is a road network dataset. Also, how to test that the network has been properly established especially than using ArcGIS for transportation network datasets will enforce the use of ESRI Network dataset model even if your data is stored in oracle spatial?! your respond is highly appreciated and i hope this thread also get a clear response (with the steps if possible)  from ESRI Geodatabase and Network development team
