Draw toolbar-Please help
10797
11-03-2011 02:24 PM
ShaundraPatterson
I am working on a class assignment and I need to have the draw toolbar on the bottom of my exercise in ArcMap; however, I do not have a draw toolbar and I tried looking for by searching ArcMap 10 to see if I could manually place the toolbar in ArcMap. I haven't be able to locate this feature and I really need it for class. Does anyone know how to install this feature without having to unintall and reinstall ArcGIS
...I'm in the fifth week of class and could really use some valuable expertise.
MelitaKennedy
Esri Notable Contributor
Right-click the mouse to the right of the existing toolbars. That will bring up a context menu that lists all toolbars. Visible ones will be checked. Check on the Draw toolbar. It will be appear near where you clicked. If you have to, you can then click-and-hold to drag it around. The easiest place to click-and-hold for me is at the left of the toolbar. The cursor will change to 4 arrows.
Melita
ShaundraPatterson
Thank you for your help
