ArcSDE 10 - 64 bit Insatll: Error 1310 - Win2008R2 Server
853
07-02-2011 05:16 AM
AntonioPerez1
Alright folks, in need of some help here.
I am trying to configure things on a test environment before going live in production and keep hitting the same snag. It's gotten to the point where I'm about the pull the little bit of hair I have left out.
Scenario:
- Installed clean Windows 2008 R2 Server OS Standard 64 bit
- Installed SQL Server 2008 R2 Enterprise 64 bit
- Try to install ArcSDE 10.0 for 64 bit
It seems to go ok until it gets right tothe end and returns:
Error 1310. Error writing to file: msvcp80.dll. Verify that you have access to that directory.
Here is the kicker, I've enabled the built-in administrator and even make sure to run the installer as "administrator"
These are all clean installs on a clean OS. I don't think the dll is the problem, it's the access. I am sure if I removed it I'd still get it with another assembly.
Also, just for the fun of it, I went ahead and rand ArcSDE 32 bit and low and behold I had no problems. It ran great.
Ok, so I am thinking this is specific to the 64bi installer for ArcSDE but need help figuring it out. Who's with me?
Thanks - Tony
AmandaOShea
Did you install ArcSDE under Program Files or Program Files (x86)?
FaisalShah1
Error 1310 is one of the common error which is found on computers and the computer working slow when this error effect to computer. I have found some useful solutions about error 1310. I am sharing these solutions.
  1. Insert the disc that you used to install Windows 7.
  2.     Click Start button on your Taskbar.
  3.     Select Run option.
  4.     Type the following command and press ENTER.
