How to send Feature Class of File Geodatabase in ArcCatalog to ArcMap for drawing?
2106
07-02-2014 12:04 PM
ScottChang
Hi all,
In ArcCatalog 10.2.2, I have created a File Geodatabase (sc.gdb) that has a "Point" feature class (biraja) with the Spatial data (X,Y-coordinates and Z-elevation) and non-Spatial data (chemical results/data, etc.) - see the attached file for details.  How can I send the feature class (biraja) of File Geodatabase in ArcCatalog to ArcMap 10.2.2 for getting the mxd drawing?  Please kindly help, advise and respond.
Thanks in advance,
Scott Chang
JoeBorgione
Hi all,
Thanks in advance,
Scott Chang
Open arcmap and drag and drop the feature class from arccatalog.
That should just about do it....
