Geocode Addresses do not work it
1499
07-02-2014 09:17 AM
Jesus_ADiaz_S
I need create a Geocode Addresses to updload a set of address and convert it to points, but a can do this. I have ArcGis 10.1 SP1.
Do you know what it's happened?
JoeBorgione
I'm afraid your attached graphic is confusing to me; I see a network dataset.
If you want to create an address locator, start here:  http://resources.arcgis.com/en/help/main/10.1/#/What_is_geocoding/002500000001000000/
Jesus_ADiaz_S
Thank for your answer
but...
the attached image shows that all properties of the drop menu are disabled: the (Zoom To... Pan to....). When I want to execute Geocode Addresses, it doesn't draw any point;  however the attribute table contains all rows.
