How to delete the name of a replica,
7579
13
02-01-2013 01:48 AM
JamalNUMAN
Legendary Contributor
I???m wondering if these is a way to delete the name of replica create.
[ATTACH=CONFIG]21296[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
AnthonyGiles
Honored Contributor
Jamal,
By right-clicking an individual replica, you bring up a context menu with the following options:
Rename???Renames the replica; type a new name and press ENTER.
Unregister???Unregisters the replica; if a synchronization version exists, it will also be removed.
View log???Opens the Replica Log; this option is only available for one-way and two-way replicas. The Replica Log is discussed in more detail below.
Refresh???Refreshes the replica; the latest state of the replica properties are displayed.
Validate schema???Validates the replica schema; a progress bar monitors the status of the validation. This automatically corrects a replica that contains invalid datasets. Datasets can become invalid if they have been renamed, deleted, or unversioned.
Properties???Opens the Replica Properties dialog box. Replica properties are discussed in more detail below.
Regards
Anthony
AnthonyGiles
Honored Contributor
Jamal,
Regards
Anthony
JamalNUMAN
Jamal,
Rename�??Renames the replica; type a new name and press ENTER.
Unregister�??Unregisters the replica; if a synchronization version exists, it will also be removed.
View log�??Opens the Replica Log; this option is only available for one-way and two-way replicas. The Replica Log is discussed in more detail below.
Refresh�??Refreshes the replica; the latest state of the replica properties are displayed.
Validate schema�??Validates the replica schema; a progress bar monitors the status of the validation. This automatically corrects a replica that contains invalid datasets. Datasets can become invalid if they have been renamed, deleted, or unversioned.
Properties�??Opens the Replica Properties dialog box. Replica properties are discussed in more detail below.
Regards
Anthony
Very much appreciated Anthony for the reply.
This means that the �??unregister�?� option is the one used to �??delete�?� replica from the database. Is that correct?
[ATTACH=CONFIG]21344[/ATTACH]
Best
Jamal
Jamal Numan
AnthonyGiles
Honored Contributor
Yes that's correct,
Regards
Anthony
JamalNUMAN
Yes that's correct,
Regards
Anthony
Thanks!
best
Jamal
Jamal Numan
HelgePaul1
Is it possible to do this with a Python Script?
Cause i want to delete a replica registration name in a batch job.
Thx.
Paul
JoeBorgione
When you unregister a replica, be sure to do it on both ends; you need to 'cut the cord' between parent and child on the parent end and the local/ child end as well.
That should just about do it....
JamalNUMAN
Many thanks Joe. Good to know this point.
[ATTACH=CONFIG]25513[/ATTACH], [ATTACH=CONFIG]25514[/ATTACH]
Best
Jamal
Jamal Numan
HelgePaul1
It is possible to do this with a python script?
Can you send me a sample?
Thx.
Paul
WilliamCraft
If you perform the unregister on the replica as the replica owner (user) it works cleanly.  If you do this as any other user (even as SDE) it may not get deleted entirely, requiring the use of SDE command line to delete sync send versions.  That's been my experience at least...
