How to delete SDE database that was already dropped in SQL Server
10365
12
06-23-2016 11:41 AM
GeorgeClark
I am relatively new to the ArcGIS world but am experienced with SQL Server.  We are geo-enabling a database that already exists in SQL Server.  In preparation for deploying to Test and later to Production, I am writing a how to guide, to make all the steps consistently reproducible.  Before starting, I took a backup of the database.  After geo-enabling the database, I missed documenting a step in ArcCatalog.  Without thinking, I quickly dropped the database in SQL Server, and restored it from the backup, to simply start over.  Now, although the restored non-geo-enabled database is what I have in SQL Server, ArcCatalog still sees the database as geo-enabled.  In ArcCatalog, when I right-click on the database connection, the Enable Geodatabase option is disabled.
Corrective action so far.
Delete the connection in ArcCatalog and recreate it:  No help.
Delete the connection in ArcCatalog, then drop the database in SQL Server, then restore the database with the same name, then recreate the db connection:  No help.
Basically is seems that ArcCatalog now/still recognizes the database as a geo-enabled and registered database.  I do not want to change the name of the database.
How can I clean this one database out and start over?
GeodatabaseEnterprise GIS
GeorgeClark
Firstly, thanks to Asrujit and Rex for your assistance, I appreciate it.
For a reason unrelated to this issue, at the end of the day, we restarted our ArcGIS server.  We added
RAM and had to restart.
After restarting, Tina M. (ESRI Tech) called.  We opened ArcCatalog again, to see review the situation.  This time the Enable Geodatabase text color was black again, without us doing anything.  Never the less at my request, we went through the process of dropping the database, and bringing it back in, and things worked OK.  It seems that something was amiss with the server, and when my folks restarted it, the problem cleared.  For the benefit of anyone else who finds this discussion, I will summarize and include some info, for other “newbees” like me.
Before starting, note that we cannot use a Basic License to do this task (from Asrujit).
(from Tina)
Steps to create the geodatabase.
  1. Create your SQL Server database in SQL Server
  2. Create your database connection in ArcCatalog
  3. Enable the database as a geodatabase using ArcCatalog
    - Open the database connection
    - In the Catalog Tree, right-click on the database connection and select Enable Geodatabase
  4. Register the database connection in ArcGIS for Server
Steps to delete the geodatabase (the official way) -- How to clean out a database and start over.
  1. In ArcCatalog remove the connection from the data store
  2. In ArcCatalog, remove the database connection
  3. In SQL Server, drop the database
In my case today, what we did was…
- In SQL Server, just drop the table again
- In SQL Server, restore it from the same backup as I did before, so it had the same name as I wanted
- In ArcCatalog, since I still had the database connection, right-clicked on Enable Geodatabase
- We checked the database properties, and the table was already registered
Conclusion:  What I was trying to do earlier should have worked, but something was amiss and restarting our ArcGIS server cleared that problem.  After the restart, everything worked properly.
AsrujitSengupta
Did you close the ArcCatalog interface...reopen it and then check?
GeorgeClark
Yes, I did.  I also closed everything out, restarted my machine, and rechecked.
AsrujitSengupta
In SQL Server Management Studio...do you still see the SDE Repository tables inside that database?
GeorgeClark
No.  I took the pre-deployment backup before geo-enabling the database, and that is what I restored from (a "regular" SQL Server database).
GeorgeClark
Here is some additional info that may or may not be helpful.
We have our ArcGIS (version 10.3) running on one server.  Our SQL Server (V2012) is on a different server.
I am running ArcCatalog (10.3.1) from a laptop running Windows 7 Ultimate SP1.
AsrujitSengupta
I hope you are not using a Basic License of ArcGIS Desktop. The Enable Geodatabase option will be greyed out in that case
GeorgeClark
No.  We are using ArcGIS 10.3.1 for Desktop
License type:  Advanced.
If I create a connection to one of our other "regular" SQL Server databases, the Enable Geodatabase... option text color is black.  When I started this process, the option text color was black also, but it changed to grey, after I ran the Enable Geodatabase process, which made sense.
AsrujitSengupta
The thing is that if ArcGIS was considering it as an Enterprise geodatabase, you will not even get the option 'Enable Geodatabase' anymore.
The fact that it still is showing the option 'Enable Geodatabase', though its greyed out...indicates that ArcGIS considers it as a simple database.
But the question remains as to why that option is greyed out....
RexRobichaux2
Hi George,
What user are you using to connect to the database with in ArcCatalog currently? It sounds like the sde login / user / schema might have been altered or deleted and normally needs to be recreated in SQL Server before the enable geodatabase tool can be ran on the client (ArcMap / Catalog) side of things. The following SQL code was ran (in SQL Server 2014 however, and at ArcGIS version 10.4.1)  to successfully prepare a database to be enabled into a geodatabase using the tool in ArcMap / Catalog. The database being enabled = Testtwo and the filename path should be the directory on the SQL Server server where your MDF (data file) and LDF (log file) reside. The first portion is altering the database properties for configuration, the second portion creates a login, user and schema named "sde" and adds sde to the bd_owner role, and finally the last portion grants the necessary permissions to sde. I hope this is of some assistance to you-
USE [master]
GO
/****** Object:  Database [Testtwo]    Script Date: 6/22/2016 8:06:13 AM ******/
CREATE DATABASE [Testtwo]
CONTAINMENT = NONE
ON  PRIMARY
( NAME = N'Testtwo', FILENAME = N'C:\Program Files\Microsoft SQL Server\MSSQL12.MSSQLSERVER\MSSQL\DATA\Testtwo.mdf' , SIZE = 3072KB , MAXSIZE = UNLIMITED, FILEGROWTH = 1024KB )
LOG ON
( NAME = N'Testtwo_log', FILENAME = N'C:\Program Files\Microsoft SQL Server\MSSQL12.MSSQLSERVER\MSSQL\DATA\Testtwo_log.ldf' , SIZE = 1024KB , MAXSIZE = 2048GB , FILEGROWTH = 10%)
GO
ALTER DATABASE [Testtwo] SET COMPATIBILITY_LEVEL = 120
GO
IF (1 = FULLTEXTSERVICEPROPERTY('IsFullTextInstalled'))
begin
EXEC [Testtwo].[dbo].[sp_fulltext_database] @action = 'enable'
end
GO
ALTER DATABASE [Testtwo] SET ANSI_NULL_DEFAULT OFF
GO
ALTER DATABASE [Testtwo] SET ANSI_NULLS OFF
GO
ALTER DATABASE [Testtwo] SET ANSI_PADDING OFF
GO
ALTER DATABASE [Testtwo] SET ANSI_WARNINGS OFF
GO
ALTER DATABASE [Testtwo] SET ARITHABORT OFF
GO
ALTER DATABASE [Testtwo] SET AUTO_CLOSE OFF
GO
ALTER DATABASE [Testtwo] SET AUTO_SHRINK OFF
GO
ALTER DATABASE [Testtwo] SET AUTO_UPDATE_STATISTICS ON
GO
ALTER DATABASE [Testtwo] SET CURSOR_CLOSE_ON_COMMIT OFF
GO
ALTER DATABASE [Testtwo] SET CURSOR_DEFAULT  GLOBAL
GO
ALTER DATABASE [Testtwo] SET CONCAT_NULL_YIELDS_NULL OFF
GO
ALTER DATABASE [Testtwo] SET NUMERIC_ROUNDABORT OFF
GO
ALTER DATABASE [Testtwo] SET QUOTED_IDENTIFIER OFF
GO
ALTER DATABASE [Testtwo] SET RECURSIVE_TRIGGERS OFF
GO
ALTER DATABASE [Testtwo] SET  DISABLE_BROKER
GO
ALTER DATABASE [Testtwo] SET AUTO_UPDATE_STATISTICS_ASYNC OFF
GO
ALTER DATABASE [Testtwo] SET DATE_CORRELATION_OPTIMIZATION OFF
GO
ALTER DATABASE [Testtwo] SET TRUSTWORTHY OFF
GO
ALTER DATABASE [Testtwo] SET ALLOW_SNAPSHOT_ISOLATION ON
GO
ALTER DATABASE [Testtwo] SET PARAMETERIZATION SIMPLE
GO
ALTER DATABASE [Testtwo] SET READ_COMMITTED_SNAPSHOT ON
GO
ALTER DATABASE [Testtwo] SET HONOR_BROKER_PRIORITY OFF
GO
ALTER DATABASE [Testtwo] SET RECOVERY FULL
GO
ALTER DATABASE [Testtwo] SET  MULTI_USER
GO
ALTER DATABASE [Testtwo] SET PAGE_VERIFY CHECKSUM
GO
ALTER DATABASE [Testtwo] SET DB_CHAINING OFF
GO
ALTER DATABASE [Testtwo] SET FILESTREAM( NON_TRANSACTED_ACCESS = OFF )
GO
ALTER DATABASE [Testtwo] SET TARGET_RECOVERY_TIME = 0 SECONDS
GO
ALTER DATABASE [Testtwo] SET DELAYED_DURABILITY = DISABLED
GO
ALTER DATABASE [Testtwo] SET  READ_WRITE
GO
USE [Testtwo]
GO
CREATE USER [sde] FOR LOGIN [sde]
GO
USE [Testtwo]
GO
ALTER USER [sde] WITH DEFAULT_SCHEMA=[sde]
GO
USE [Testtwo]
GO
CREATE SCHEMA [sde] AUTHORIZATION [sde]
GO
USE [Testtwo]
GO
ALTER ROLE [db_owner] ADD MEMBER [sde]
GO
grant create function to sde;
grant create procedure to sde;
grant create view to sde;
grant create table to sde;
