How do I know if 'move edits to base' was setup
1331
12-22-2010 07:16 AM
JaninaBarnes
I have inherited an Oracle SDE geodatabase, and need to find details about how it is setup.  How can I find out whether the feature datasets are versioned with the option to  'move edits to base' or not?  I haven't found that information in the repository.
CherylCleghorn
Janina
From ArcCatalog, you can look at the properties of the featureclass/table on the General tab. The Versioning section at the bottom will display the versioning method e.g. 'This feature class is registered as versioned and moving edits to base'
Regards
Cheryl
CherylCleghorn
Janina
Regards
Cheryl
