Geocoding with spatial offset
3141
08-24-2021 09:13 AM
RallyeShen
I am trying to geocode addresses of the following form:
"138th St and Lincoln Ave SE corner"
"109th St South side, 100 feet East from 1st Ave"
According to a previous Esri Community post, I should be able to geocode spatial offsets if I use a locator I create myself. Using street centerlines reference data, I applied the Create Locator tool in ArcGIS Pro to create a Street Address locator.
But the offsets are still not being recognized, even with the new locator. When I type a spatial operator into the Locate pane, such as "100 feet East from 109th St and 1st Ave", the results only show the intersection. This is true of both ArcGIS World Geocoding Service and my own locator.
Is there anything specific I have to do when creating the locator for it to recognize spatial offsets?
The previous post I saw was this one: https://community.esri.com/t5/data-management-questions/geocoding-intersections-with-an-offset-based...
Thanks!
ShanaBritt
@RallyeShen Locators built with the Create Locator tool and the ArcGIS World Geocoding Service do not support searching with a spatial offset. Only locators created using the Create Address Locator tool in ArcMap or ArcGIS Pro 2.6 or earlier support geocoding using a spatial offset as described in https://desktop.arcgis.com/en/arcmap/latest/manage-data/geocoding/finding-an-address-about.htm#ESRI_... .
ShanaBritt
RallyeShen
Thanks! I've found a workaround.
MikeRodriguez
Hey Rallye, I know this was posted last year but, would you be able to provide the workaround you've found?
Thank you in advance
