Failed to register as versioned
14678
12
02-10-2015 09:13 AM
ChrisGoessl
Here is my issue. I created a checked out replica feature class (StreetSigns), was able to syncronize the data back to the SDE with reconcile and post information checked. The process was completed and closed down. I deleted the replicated feature class.
Now I am getting this error.
"Failed to register as versioned. Operation not supported on a table that is moving edits to base."
This error is coming when I am creating a version for a feature class that is located in the same dataset as the StreetSigns. I have stopped all services thinking that it might be a schema lock, but I still get the same error message.
Also, the StreetSigns feature class had a representation for symbology and now over half of the symbols are missing.
I have checked all versions and ensured that all have been reconciled and posted. No issues with any of the versions.
I am in need of some guidence
DanaNolan
No tool, just ArcCatalog. The unregistered files are in the same SDE gdb, sometimes in the same feature dataset, sometimes loose or in another dataset. I just keep checking properties in Catalog until I find the culprit.
I also had the problem of not being able to unregister the feature data set. . I inherited a system that no one could figure out to edit for a long time. As I have fixed the existing tables and know to register new annotation, this problem is fading.
Lake_Worth_BeachAdmin
Here is a python script to register all datasets as versioned nay that fail will be added to a list and printed to console at the end so you can examine each one...
import arcpy
sde_path = r"C:\Users\path\to\sde\connection"
arcpy.env.workspace = sde_path
datasets = arcpy.ListDatasets('*', 'ALL')
failedData = []
for data in datasets:
   try:
      arcpy.RegisterAsVersioned_management(data, 'NO_EDITS_TO_BASE')
   except:
      failedData.append(data)
      continue
print 'List of Data Sets which failed to register as Versioned'
for item in failedData:
   print item
AndresCastillo
See this ESRI Technical Support article as well:
Error: Failed to register as versioned. Operation is not supported on a table that is moving edits to base:
https://support.esri.com/en/technical-article/000012902
