Exporting to google earth kmz. file
3122
10
01-16-2014 07:24 AM
matttaylor1
I'm fairly new to GIS and I am trying to export map data (crude oil pipelines) to google earth...I have tried the export using the toolbox export to kml, but it seems to only work on certain layers. Can I also export a layer as a shapefile?
thanks in advance
808707
Also, Is it possible to export a layer as a kmz. file which seems to be much easier to work with in google pro rather than a shape file?
In the mean time check out the following tools. They should do what you want.
Layer to KML
Map to KML
You can use the seach window to find them.
