Error on a spatial view with GROUP BY clause
1554
06-21-2012 01:18 AM
StefanoIacovella
Hi all
I am trying to use a spatial view with aggregate functions.
The view was built with this query:
SELECT
    C.COUNTRY_CODE CNTRY_CD,
    MAX (C.COUNTRY_NAME) CNTRY_NM,
    SUM (GAS) AS GAS, SUM (OIL) AS OIL,
    SUM (ENCO) AS ENCO,
    SUM (WELLCOST) AS WELLCOST,
    SUM (UEC) AS UEC,
    SDE.ST_CENTROID (SDE.ST_AGGR_UNION (SHAPE)) AS SHAPE,
    MAX (C.OBJECTID) AS OBJECTID
FROM
    ENGIS.CDB_CNCSSN C,
    EXPL.PORT_CNTRY_LEASE_4_GIS_V1@CDBPA01_ENGIS P
WHERE
    P.CNTRY_CD = C.COUNTRY_CODE
    AND P.LEASE_CD = C.LEASE_CODE
    AND C.CNCSSN_BLCK_NBR = 1
GROUP BY C.COUNTRY_CODE;
I then registered it in ArcSDE with the following command
sdelayer -o register -l UPD_XAA_PORTFOLIO_CNTRY_P_V,SHAPE -R 204 -e p -t ST_GEOMETRY -C OBJECTID,USER -u username -p password@service_name -i sde:oracle10g
ArcSDE 10.0  for Oracle10g Build 1937 Tue Aug 16 16:08:18  2011
Layer    Administration Utility
Successfully Created Layer.
The record count in sqlplus return 32 rows
SQL> select count(*) from UPD_XAA_PORTFOLIO_CNTRY_P_V;
  COUNT(*)
        32
But when performing a feature_info I got only 16 records
C:\Users\gdladmin>sdelayer -o feature_info -l UPD_XAA_PORTFOLIO_CNTRY_P_V,SHAPE -r all -u username -p password@service_name -i sde:oracle10g
Row Id,FID,Entity Type,Annotation,Cad Data,Number of Points,Number of Parts,Number of Subparts,Self-Touching Rings,Minimum Precision,Verification
1666,1085528320,P,F,F,1,1,0,F,Basic,0
1730,1083836416,P,F,F,1,1,0,F,Basic,0
1842,1084131328,P,F,F,1,1,0,F,Basic,0
376,1083901952,P,F,F,1,1,0,F,Basic,0
947,1083971584,P,F,F,1,1,0,F,Basic,0
661,1084016640,P,F,F,1,1,0,F,Basic,0
1907,1080778752,P,F,F,1,1,0,F,Basic,0
1014,1081573376,P,F,F,1,1,0,F,Basic,0
667,1084075008,P,F,F,1,1,0,F,Basic,0
954,1083021312,P,F,F,1,1,0,F,Basic,0
1774,1084081152,P,F,F,1,1,0,F,Basic,0
929,1082435584,P,F,F,1,1,0,F,Basic,0
1830,1082808320,P,F,F,1,1,0,F,Basic,0
960,1084083200,P,F,F,1,1,0,F,Basic,0
1849,1084084224,P,F,F,1,1,0,F,Basic,0
229,1083158528,P,F,F,1,1,0,F,Basic,0
Total rows examined:          16
Total invalid shapes:          0
If I open the feature class in ArcCatalog preview it shows 32 points on the map but if I switch to table preview there are no records shown. Trying to do an info on any points retun nothing.
Am I doing some errors?
Thank you in advance for your suggestions
Cheers
Stefano
StefanoIacovella
I suspected ArcSDE could be troubled with not sequential values in OBJECTID FIELD, so I made anot her trial.
Removed
And inserted
row_number() OVER (ORDER BY MAX(C.OBJECTID)) As OBJECTID
the OBJECTID value are now 1..n
Unfortunately this does not solved my issue.
Hope someone has some suggestion
Cheers
Stefano
VinceAngelo
Esri Esteemed Contributor
The registered rowid column does not have to be sequential.  It must be reproducible
on subsequent queries, so I don't think your workaround is workable.
You've got a number of uncommon elements in this view, and most of them are going
to negatively impact performance.
I suggest you look at the output of the view in SQL*Plus, since polynomial expansion
with non-unique objectids would explain the 'sdelayer' behavior.
- V
StefanoIacovella
Angelo, thank you very much for your attention.
I did not mention in the original post but I checked uniqueness of OBJECTID in the view output
SQL>SELECT OBJECTID,COUNT(*) FROM UPD_XAA_PORTFOLIO_CNTRY_P_V GROUP BY OBJECTID HAVING COUNT(*) > 1;
no rows selected
Did I correctly understand your suggestion?
thank you for support
Cheers
Stefano
StefanoIacovella
- V
I did some further investigation
the issue seems related with the OBJECTID column type.
sdetable -o describe_long -t UPD_XAA_PORTFOLIO_CNTRY_P_V -u engis -p engis_mgr@SVILUPPO -i sde:oracle10g
Column Owner           : ENGIS
Column Table           : UPD_XAA_PORTFOLIO_CNTRY_P_V
Column Name            : OBJECTID
Row ID Column Type     : User Maintained
SDE Column Type        : SE_FLOAT64
Column Size            : 38
Decimal Digits         : 10
Null Allowed?          : True
I tryed to CAST it to INTEGER inside the SQL code with
CAST(MAX (C.OBJECTID) As INTEGER)
But after registering it the sdetable -o describe_long returns the same information
I know that this is usupported and not the best thing to do but I changed the SDE.COLUM_REGISTRY information with
UPDATE COLUMN_REGISTRY
   SET SDE_TYPE = 2,
       COLUMN_SIZE = 10,
       DECIMAL_DIGITS = NULL
WHERE TABLE_NAME = 'UPD_XAA_PORTFOLIO_CNTRY_P_V'
   AND OWNER = 'ENGIS'
   AND COLUMN_NAME = 'OBJECTID';
After this the sdetable -o describe_long reports
SDE Column Type        : SE_INT32
Column Size            : 10
Decimal Digits         : 0
and now I can access all the records in sdelayer -o feature_info and in ArcCatalog, both shapes and attributes.
C:\Users\gdladmin>sdelayer -o feature_info -l UPD_XAA_PORTFOLIO_CNTRY_P_V,SHAPE -r all -i sde:oracle10g -u **** -p ****@*****
5081,5081,P,F,F,1,1,0,F,Basic,0
1666,1666,P,F,F,1,1,0,F,Basic,0
1954,1954,P,F,F,1,1,0,F,Basic,0
1730,1730,P,F,F,1,1,0,F,Basic,0
1798,1798,P,F,F,1,1,0,F,Basic,0
1842,1842,P,F,F,1,1,0,F,Basic,0
219,219,P,F,F,1,1,0,F,Basic,0
376,376,P,F,F,1,1,0,F,Basic,0
1899,1899,P,F,F,1,1,0,F,Basic,0
947,947,P,F,F,1,1,0,F,Basic,0
1905,1905,P,F,F,1,1,0,F,Basic,0
661,661,P,F,F,1,1,0,F,Basic,0
843,843,P,F,F,1,1,0,F,Basic,0
1907,1907,P,F,F,1,1,0,F,Basic,0
1908,1908,P,F,F,1,1,0,F,Basic,0
1014,1014,P,F,F,1,1,0,F,Basic,0
5264,5264,P,F,F,1,1,0,F,Basic,0
667,667,P,F,F,1,1,0,F,Basic,0
1600,1600,P,F,F,1,1,0,F,Basic,0
954,954,P,F,F,1,1,0,F,Basic,0
1769,1769,P,F,F,1,1,0,F,Basic,0
1774,1774,P,F,F,1,1,0,F,Basic,0
1375,1375,P,F,F,1,1,0,F,Basic,0
929,929,P,F,F,1,1,0,F,Basic,0
1887,1887,P,F,F,1,1,0,F,Basic,0
1830,1830,P,F,F,1,1,0,F,Basic,0
5263,5263,P,F,F,1,1,0,F,Basic,0
960,960,P,F,F,1,1,0,F,Basic,0
684,684,P,F,F,1,1,0,F,Basic,0
1849,1849,P,F,F,1,1,0,F,Basic,0
1882,1882,P,F,F,1,1,0,F,Basic,0
229,229,P,F,F,1,1,0,F,Basic,0
Total rows examined:          32
Is there a cleaner way to inform ArcSDE about the column data type?
Cheers
Stefano
StefanoIacovella
Cheers
Stefano
CAST(MAX(OBJECTID) AS NUMBER(38))
solved the issue without any hacking on the ArcSDE catalog
Cheers
Stefano
