Issue adding Field to attributes table!
1130
06-21-2012 05:35 AM
KassieKeeney
Okay, so I have a data layer that was creating in CAD and exported as shapefile.  It was then added into ArcMap and we tried to add additional fields into the attribute table.  This all appeared to work fine, until we opened the map the next day.  The layer had that red exclamation point, so we tried to establish the layer to the data and we got the following error:
Error repairing the layer.
Number of shapes does not match the number of table records.
I have very little experience using files from CAD.  Is that the issue here?  Would it be better to covert the CAD file within ArcMap instead?
Any insight would be very appreciated!
Thanks!
Kassie
Robert_LeClair
Esri Esteemed Contributor
Hi Cassie -
This is more an issue with the shapefile itself.  Please refer to the following doc for resolution - http://support.esri.com/en/knowledgebase/techarticles/detail/39474
Hope this helps!
Robert LeClair
Esri-Denver
