draw linear polygons with a fixed width and length divisible by 4 feet
2123
03-01-2012 10:32 AM
ChrisFox2
I would like to draw polygons that are constrained such that they are no wider than 16 feet and the length is divisible by 4.
I am  working on a project which requires laying down panels for equipment to drive on that are 4 feet by 16 feet.  What I would like to do is be able to easily draw areas that will represent these panels and be divisible by the area of one panel.  ie. I draw a line and I can easily calculate the number and area of the panels.  I have tried buffering a line then calculating the numbers I need but this requires too many steps and I only have arc editor so I can't create flat ended buffers.
Any way this can be done by topology etc?
DanLee
by Esri Regular Contributor
Have a look of the Create Fishnet tool (Data Management toolbox - Feature Class toolset):
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Create_Fishnet/00170000002q000000/
Hope it does what you need to do.
ChrisFox2
i figured out that I can use strip index with no overlap and the window dimensions meeting my specs
