I have a shapefile of zip codes (n = 500), and I have a table of air pollution data by month for a 10 year span for each zip code (n = 100,000). I am using ArcGIS Desktop, and I want to use the Time Slider to display the change in air pollution by month for each zip code.
In ArcGIS Help, they mention that it is possible to display the data this way because the geography doesn't change. However, I haven't found a way to use the related data under the "Time" tab in properties.
How can I access the related records from the shapefile? Thanks in advance!
