DataBases
1693
03-12-2014 12:05 PM
PrestonStafford
Can anyone tell me is it possible to make a connection to a Access DateBase in ArcMap. If not, is possible to pull the Tables for the Access Database into a GeoDataBase.
RobertBorchert
Honored Contributor
It was possible and exceptionally handy do link Access databases.  However, newer versions of ArcGIS have taken away this possibility.
There may be a work around but I have not explored it.
There is a different workaround however.  Create a new personal geodatabase with ArcCatalog.
Then use that database as an Access database and you can load it with tables that you can bring into ArcGIS
Basically just a different way of creating and Access Database.
AsrujitSengupta
It always helps if you provide the configuration details (atleast the version of ArcGIS Desktop in this case)
HowTo:  Connect to Microsoft Access 2007/2010 (ACCDB) files in ArcGIS:
http://support.esri.com/fr/knowledgebase/techarticles/detail/32976
HowTo:  Use Microsoft Access tables in ArcGIS:
http://support.esri.com/en/knowledgebase/techarticles/detail/30770
Connecting to a Microsoft Access database in ArcGIS:
http://resources.arcgis.com/en/help/main/10.1/index.html#//005s00000023000000
SteveFranczak
So if I understand this correctly, you are displaying updateable layers in real time from an access database hosted by arcGIS? If so, can I update that database from a mobile client? So I would be adding social events to an Access "calendar" for display on a map...or is this offbase for this product?
Thanks!
