Copying ArcSde related table to file geodatabase
1099
07-16-2012 05:55 PM
ShazadTareen
Can some help me in using Python to copy feature and associated related tables to file geodatabase ( without losing the relationship). I am using ArcGIS 10
Thanks
EricMcPhee
Use
arcpy.Copy_management(in_data, out_data)
If you specify your featureclass as in_data, any related tables and relationship classes will be copied along with it.
ShazadTareen
Use
Thanks very much for the reply. I tried this before and it is just copying the feature class and related table but no releationship class.
Thanks
DanRose2
Shazad Tareen‌, did you find a resolution to this? I'm having a similar issue... the feature class and the relationship is coming over, but not the table...
Dan
