Is there a code to auto populate a field with alphanumeric values in ascending order?
1400
11-29-2018 08:59 AM
ClaytonGordon1
I have a field named FacilityID and it contains alphanumeric values that need to be populated in ascending order.  Our current work flow involves "X-ing out" the last four digits, then sorting the field in ascending order, and then finally going one by one and manually filling them in.  For example:
FacilityID                                                        FacilityID
S-LL-L18-1002                                              S-LL-L18-1002
S-LL-L18-1003                                              S-LL-L18-1003
S-LL-L18-1004                                              S-LL-L18-1004
S-LL-L18-1005     ----------------------------->    S-LL-L18-1005
S-LL-L18-xxxx                                               S-LL-L18-1006
S-LL-L18-xxxx                                               S-LL-L18-1007
S-LL-L18-xxxx                                               S-LL-L18-1008
Is there a code that can auto populate the last four digits in ascending order? We would also need to specify which number the auto populate will begin at; in this case it would be starting at 1006 and then +1 after that.
JoeBorgione
The attribute assistant as a method called Autonumber as well as GenerateID; not sure if deploying the AA would fit into your workflow or not....
All methods - Attribute Assistant | ArcGIS Solutions
