converting Lat Long to UTM xy coordinates
14506
02-10-2017 08:29 AM
janehansen
HI I have an excel spreadsheet that shows the coordinates in lat long decimal degrees.  I need to show the coordinates as utm x y.  To be more specific I need to have one column that shows the UTM on showing the x and one showing the y.  Is there an easier way than manually converting each decimal degree to UTM and and entering them manually within the 3 new columns named UTM X Y
Jane
MitchHolley1
Have you tried this tool?  Convert Coordinate Notation—Data Management toolbox | ArcGIS Desktop
I'm assuming you're using ArcGIS.
janehansen
Yes I am, and thanks I will give it a try
