Can't add data from geodatabase
8121
14
12-20-2015 09:15 AM
RyanSmith
I am trying to connect to a geodatabase I obtained from a local city government. When I try to add data from it in arcmap or view it in arccatalog, the .gdb apears as a regular folder and if I click on it nothing else comes up. Opening it through windows explorer reveals it has 262 items in it. Any idea why can't I add data from it?
Tags (1)
RyanSmith
I'm assuming you mean right clicking in windows explorer, I didn't see any
way to right click anywhere else. Tried it, there was no update option. I
also noticed, the new database was waaaaay smaller than the original. Down
to about 2 mb from 780 mb.
On Sun, Dec 20, 2015 at 8:58 PM, Rebecca Strauch, GISP <[email protected]>
RebeccaStrauch__GISP
I meant to right-click for the properties in Catalog.  Or is it still not showing up in Catalog?
RyanSmith
They are using version 10.2. That should be compatible right?
On Sun, Dec 20, 2015 at 9:34 PM, Rebecca Strauch, GISP <[email protected]>
It should be, but if you see the upgrade button, I would try it (have a backup, of course).  Short of going back to the data owner, and if you have already tried all that was suggested previously, and you tried Resetting your ArcGIS application profile​  then that might be the last thing I can think of to try. The resetting your profile is always a good first try when things go wonky....resets things on your side, in case something it conflicting.
If it's a shareable download, one last options is to upload it here (you'll need to use the Advanced editor in the upper right of your edit window....and need to be in a browser tab "outside" of your inbox....that is, open the thread up in a new tab).  Then others can take a look at it to see if it's a data issue of issue on your end.
RyanSmith
The zip trick worked. Thanks for all the help.
On Tue, Dec 22, 2015 at 11:02 AM, Rebecca Strauch, GISP <[email protected]>
