Can't add data from geodatabase
8091
14
12-20-2015 09:15 AM
RyanSmith
I am trying to connect to a geodatabase I obtained from a local city government. When I try to add data from it in arcmap or view it in arccatalog, the .gdb apears as a regular folder and if I click on it nothing else comes up. Opening it through windows explorer reveals it has 262 items in it. Any idea why can't I add data from it?
Tags (1)
RobertScheitlin__GISP
Ryan,
  Sounds like the data got corrupted during transfer. It is best to have the originator zip the file for transfer or better yet use map packages for transferring data.
DanPatterson_Retired
don't use gdb's much, but you mentioned municipality.. is there any chance that they licensed it?
Generate File Geodatabase License—Help | ArcGIS for Desktop
perhaps corrupt or improperly sent, as previously indicated... give this a try
Recover File Geodatabase—Help | ArcGIS for Desktop
or cruise around some of the other tools here.
An overview of the File Geodatabase toolset—Help | ArcGIS for Desktop
RebeccaStrauch__GISP
I have moved it to Managing Data as well, since it has nothing to do with the API
RyanSmith
Hi, thanks for the responses. I am wondering if it got corrupted, I will
ask to see if they can zip it for me. I doubt that they have licensed it, I
can ask but I think they would have mentioned it if they had. And as for
the script... I don't really know much about Python but I could give it a
try.
Ryan... it is a tool in arctoolbox ... Data Management tools, File geodatabase ... etc etc.
Recover File Geodatabase—Help | ArcGIS for Desktop no need to script
RyanSmith
ah-ha... I just saw syntax and assumed that meant a script.
Ok, so I ran the recovery and created a new gdb to output the data into.
When I try to add data, the new gdb shows up as you would expect, but I get
an error message: "Failed to connect to database. This release of the
GeoDatabase is either invalid or out of date. [Invalid Geodatabase
release]." So... does that mean that the release they're using is
incompatible with my version, or something else?
could be, you would have to know the version of arcmap they are using and yours...I haven't looked at the other tools in the toolbox.  Probably time to give them a call in the morning...
PS then there is this toolset An overview of the Geodatabase Administration toolset—Help | ArcGIS for Desktop
Try aright-click to open the properties of the gdb (recommend doing this on the new one or a copy of the original) and seeing if the option to "update" is there.  That might do the trick .
