ArcGIS Pro Locator Not matching intersection with //
5704
10
06-18-2020 09:05 AM
yaserkhouja
My data use street intersection with // sign instead and. For example, Main street // 7th street. however, the geocoding result are not matching the intersection. I know in ArcMap I could change the property of locator to accept different signs with an intersection, but I can't see it with the new ArcGIS Pro locator. Any advice on how to overcome this issue?
Thanks in advance,
Robert_LeClair
Esri Esteemed Contributor
Yaser - I created my own Address Locator using the Create Address Locator geoprocessing tool.  Once I ran the tool, I went to the Catalog Pane->Locators.  Right-click->Locator Properties.  In the Locator Properties, I went to Geocoding options and scrolled down to Intersection Connectors and added the // connector option you listed in your question.  Click OK.  The address locator will now recognize Main Street // 7th Street. Hope this helps!
yaserkhouja
Yea, it will be fine with the address locator. But, I am building one with the new one "Create Locator". It does not have this option.
Robert_LeClair
Correct.  In the GP tool, Create Locator, the option to set this is not there.  You have to set it after you create the locator first as I did in my workflow and then go to Geocoding Options to set the // second.
yaserkhouja
Yea, in the new locator, I do not see this option at all. here is a screenshot;
Robert_LeClair
Scroll down further in the Geocoding Options window using the right scroll bar on the UI.  Do you see "Intersection connectors"?
yaserkhouja
No, I do not see it.
Robert_LeClair
What address locator style are you creating?  For example, "US Address-Dual Ranges" or "General Gazetteer".
yaserkhouja
I am building the new locator tool which merges everything together. It is different than address locator. Looks like I can't change the intersection connectors. Maybe I will transform my data before geocoding.
Robert_LeClair
Ah now, I understand.  Different GP tool. I'll do some digging and see what I can find.
