Arc Pro: draw a box zoom possible?
20389
11
12-07-2019 01:04 PM
KenLucas
I understand about use the explorer tools and the mouse for zooming. Does arc pro offer zoom buttons, like arc map, for drawing boxes around an area to zoom in?
MarkBockenhauer
The Explorer tool with shift key + left mouse drag is the way to zoom with rectangle.  No other button "zoom tools"
MarkBockenhauer
AidaBahtijarevic
That  would be fine just if it worked!!!
I tried and rectangle frame shows on the screen but it does not zoom in.
DenisBeaulne
I am running into the same issue - I'd like to draw a box to zoom into, but I can't seem to get that to work.  I tried @MarkBockenhauer 's suggestion, also with no luck.
ChetHugo
Why would mine zoom out when I do this?
Gianna_BBSRC
This worked great for me! So glad I finallly decided to google this. I was missing the zoom box of ArcMap days.
I'm using ArcGIS Pro 2.8.2
Moulay_AnwarSounny-Slitine
I put together a quick video on how to zoom on your map in ArcGIS Pro.
https://youtu.be/N0tU3d0GKhQ
wayfaringrob
Honored Contributor
There is a command called "rectangle zoom in" (and "out") that can be accessed via command search (top right) or added to the QAT/Ribbon.
Sean_Wray
Can you share with us how to add these tools to the ribbon?
wayfaringrob
Honored Contributor
Once you see it in command search, R click > Add to QAT.
To get them on the ribbon, I believe you do that from Pro settings but I'm no expert at that. (From that Customize the Ribbon button, somehow)
