data encryption in Enterprise Geodatabase
3209
05-30-2017 03:45 AM
NicoleSulzberger
I need to manage sensitive data in my Enterprise Geodatabase, and would like to encrypt the data.  I am aware that Esri is -supporting TDE (Transparent Data Encryption) both for MS SQL Server and Oracle, but with TDE the Database-Administrator is still able to see the data in the database, which is not acceptable in our case.
Is Esri supporting this kind of encryption, e.g. row based encryption (Oracle), Oracle Label Security (Oracle) or "Always Encryped" (MS SQL Server)?
thanks for your help!
kind regards, Nicole
RafaelFernandesdeSouza
Hello, @NicoleSulzberger!
The answere to your question, unfortunetly is no. Esri do not support this type of encryption yet.
Other options for encryption are this:
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-sql-server/connections-encryp...
Transparent Data Encryption (TDE)—ArcMap | Documentation (arcgis.com)
Best Regards,
Rafael F Souza
Marco_AlejandroBonilla
@RafaelFernandesdeSouza is there any workaround that you know of to store encrypted data in a geodatabase? Ex. Credit card numbers?
MichaelWainright2
Does anyone have any updates on this topic?
We are using Postgresql, which does not have TDE out of the box.
