Address Locator - Dual Range: Not matching Single-line input
1410
10-16-2017 07:34 PM
FizzaMustehsan1
Hi!
I am using ArcMap 10.5.
I created a Dual Range - Address locator to geocode addresses from a .CSV file. This .CSV file contains Full Address in the first column separated by ',' and the address is also present in Multi-line input format with a column for each of the following: StreetName, City, Zip and State.
Now my problem is when I geocode using Multi-line input format it works perfectly, but when I use Single-line input using the Full Address column it produces zero match!
What am I doing wrong?
How can I fix this?
Thank you,
Fizza
LarryWilliams
Are you still having this issue?  If you are can you provide some sample addresses?
ShanaBritt
Does the address in the FullAddress field contain city, state, or zip?
Does your single line csv look similar to below?
ID,FullAddress
1,"380 New York St, Redlands, Ca"
2,"Nevada St & Redlands Blvd, Redlands, Ca"
