Hi!
I am using ArcMap 10.5.
I created a Dual Range - Address locator to geocode addresses from a .CSV file. This .CSV file contains Full Address in the first column separated by ',' and the address is also present in Multi-line input format with a column for each of the following: StreetName, City, Zip and State.
Now my problem is when I geocode using Multi-line input format it works perfectly, but when I use Single-line input using the Full Address column it produces zero match!
What am I doing wrong?
How can I fix this?
Thank you,
Fizza
