When copying featureclasses from a file geodabase to SDE, retain the float dataype instead of converting to a double
572
04-21-2017 11:50 AM
Status: Open
ColleenFarrell
I recently ran into the following problem:
Problem: Data type in a feature class converts to double when exported from a non-spatial database t...
I had assumed the data copied to the SDE geodatabase as it was defined in the file geodatabase.  We discovered later that the copy converted the float fields to doubles.  I would like a way to specify the precision and scale when copying a float to an sde geodatabase.  If this isn't possible, at a minimum, there should be a warning that the data is not copying as defined.
