Integrate with Sparx Systems Enterprise Architect CASE tool for Geodatabase modeling
7469
15
07-29-2010 09:58 AM
Status: Under Consideration
PeterFitts
In previous versions ESRI supported Visio or Rational Rose as a CASE tool for Geodatabase modeling. These CASE tools can be cumbersome to use or expensive. We are seeing more and more that Enterprise Architect (http://www.sparxsystems.com.au/products/ea/8/index.html) is the CASE tool of choice in projects where data model documentation is required, but without Geodatabase integration it is difficult to use for data model development.
Enterprise Architect is relatively inexpensive CASE tool when compared to Rational Rose, and it performs significantly better than Visio. Having the Geodatabase types integrated into EA, similiar to how they are in Visio and Rational Rose would provide a robust CASE tool for Geodatabase development that does not require an ESRI CASE tool to be developed, and it would satisfy the user community that has requirements for data model documentation.
15 Comments
MarceloMarques
The CASE tool needs to support annotations, feature linked anno, dimensions, etc, things that the Visio CASE tool always lacked.
MarceloMarques
MarceloMarques
https://community.esri.com/ideas/1802
 Merge GDBT, MXDPERFSTAT, GDBDesigner, GDBDiagrammer, GDBReporter into ONE extension
danan
Agreed, but why limit things to one tool? The XML Schema of the Geodatabase seems to contain everything one needs to create a UML Profile of the Geodatabase. If interested, please vote on this idea:
https://community.esri.com/ideas/2720
danan
For what it's worth Esri Professional Services (EPS), the consulting arm of Esri, seems to use Enterprise Architect already. So your idea makse great sense. Certainly, Sparx Systems likes to showcase that Esri users EA, e.g.:
http://www.sparxsystems.com.au/downloads/pdf/esri_lbs_delivery_case_study.pdf
And here's the UML Profile of the Geodatabase idea link, active this time:
juliaharrell
EA is a great choice, but this one already has support for spatial features and works with both Oracle 10g Locator and PostGIS. Maybe esri should provide support for both.
http://geomaticblog.net/2010/08/31/moskittgeo-from-uml-to-spatial-databases-and-back/
danan
@pfitts, this is indeed good news. Sparx Systems would like user feedback on its ArcGIS UML Profile. Please see the response from Ben @ Sparx Systems on the following support forum thread:
http://forums.arcgis.com/threads/14543-Is-it-possible-create-annotation-feature-class-with-Case-tool
Dana Nibby
GIS for DBAs. Database Concepts for GIS
http://spatialdba.com
by Anonymous User
Hi Everyone,
Thank you for you feedback on this Idea. We have currently moved this to Under Consideration for a future release.
Regards,
Despina
JuanBohorquez1
Additionally, to model all the elements within the CASE Geodatabase, for example, Topology Rule, Mosaic Dataset, Raster, Spatial references, adn others.
