Enable "Allow NULL Values" change when importing schema
1566
11-23-2010 09:04 AM
Status: Already Offered
RichardFairhurst
When Creating a new Schema it is possible to directly change all of the settings of an imported field (Field Name, Field Type, Field Alias, Default Value, Domain, Length, Precision, Scale) except for the Allow NULL Values property.  Clicking on that property after importing a schema does not trigger the normal combobox behavior that lets a user choose to enable or disable that property.
There are only two ways to change the Allow NULL Values property.  The first is to change the field type to a different type.  However, by changing the field type other field properties are reset.  After changing back to the original type just to alter the Allow NULL Values property, user error can easily occur in the process of trying to remember and restore the other properties to what was originally imported.
Most people (including myself prior to this post) will not realize that changing the type can enable the Allow NULL Values property.  They will normally delete that field and recreate it, which may cause even more user error when restoring all of the settings just to change the Allow Null Value property.  This just happened to me on a complex feature class I spent hours rebuilding and I am ticked.
1 Comment
SSWoodward
Thank you for the idea!
In both ArcGIS Pro and ArcMap, the 'Allow Null Values' property of an imported field is now editable while importing a schema. For information on importing schemas from other feature classes you can refer to the link below.  The article is specific to ArcMap, however the process is the same in ArcGIS Pro.
https://support.esri.com/en/technical-article/000013772
For more information about creating new feature classes and importing existing schemas I've included some additional links below.
Importing Data:
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/import-data.htm
Defining Feature Classes
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/defining-feature-class-prop...
