Crowdsource Manager Search Tool not working?
2907
09-14-2016 08:38 AM
by Anonymous User
Not applicable
First, I should say to Allison Muise that the September 2016 update to Crowdsource Manager looks fantastic! - the ability to add a related record works seamlessly - very much appreciated.
The application now nearly covers every functionality my client is asking of it - however there's one last hangup. The Search Tool seems to be greyed-out and disabled.
Unless I'm making an obvious oversight, this behavior seems to be present both in the Sample application and in my client's version of Crowdsource Manager.
Here is the view from the Sample application,
Search-Tool-Broken
And from my client's application:
search-tool-2
As can be seen, both of the Search tools are greyed out and disabled.
Is there a configuration step I may have missed RE: the search tool?
Something to do with the layer not being searchable?
Thanks in advance for any advice.
Tags (1)
AllisonMuise1
jamatney‌ The search is configured from the Details page of each map. It's an attribute search rather than a location search, so you'll need to specify which layers and fields you'd like to search in.
I'll add that info to the doc
AllisonMuise1
ZacharyOrdo__GISP
How do you do that?  I don't see anything to that effect in the Details page of my map.
ZacharyOrdo__GISP
Never mind, you meant the Settings tab.  There's a Details page in the Map Viewer and it doesn't have any of those settings.
Dawn_Scott
Thank you, I had the same question today and this solution worked for me.
