Crowdsourcing Questions
Latest Activity
Sort/Filter :
POST
In my organization board, I have Story Map App or Survey123 and other options of app, but no Crowdsource. Thks for yo...
Anonymous User
by Anonymous User Not applicable
in Crowdsourcing Questions Last Updated 11-06-2020
0 0
POST
Hi All,I am building a dashboard that will eventually be public-facing. The goal will be to have a feature service po...
MichelleTanner
by MichelleTanner Regular Contributor
in Crowdsourcing Questions Last Updated 06-16-2020
0 0
POST
I created a Geodatabase with different point layers and assigned domains to specific fields. In the domain menu I hav...
SteveRhyne2
by SteveRhyne2 Occasional Contributor
in Crowdsourcing Questions Last Updated 06-05-2020
0 1
POST
In Crowdsource Reporter do you need to create a custom template before you can use Enrich Reports or any of the other...
DeniseKlein1
by DeniseKlein1 Emerging Contributor
in Crowdsourcing Questions Last Updated 12-13-2019
0 0
POST
Making a defect reporting app, it seems like citizen problem reporter is the way forward.Since having a field worker ...
AndrewWalker3
by AndrewWalker3 Emerging Contributor
in Crowdsourcing Questions Last Updated 11-24-2019
0 0
POST
How easy is it to add workforce app into Citizen problem reporter?When the problem is viewed in the  manager and the ...
AndrewWalker3
in Crowdsourcing Questions Last Updated 06-01-2020
0 1
POST
Please can someone assist me with this error "Failed to read email template (html)" using the servicefunction.py, the...
Temple_Digital_DeliveryTeam
by Temple_Digital_DeliveryTeam Occasional Contributor
in Crowdsourcing Questions Last Updated 02-06-2020
0 3
POST
Is there a way to download a different file type other than csv from a report inside Crowdsource Manager? (For Exampl...
Wade_Adams
by Wade_Adams Emerging Contributor
in Crowdsourcing Questions Last Updated 09-24-2019
0 1
POST
Hi Guys,Please is it possible to disable "select the location" as a requirement when submitting a report via crowdsou...
in Crowdsourcing Questions Last Updated 09-03-2019
0 1
POST
Hi I have a question Is it possible to hide the answer after filling the commentary in Crowdsource Polling?I have to ...
BiuroRozwoju_Gdańska
by BiuroRozwoju_Gdańska New Contributor
in Crowdsourcing Questions Last Updated 09-06-2018
0 1
POST
I built the crowsourcing manager application in the portal to get users to verify a set of rail network data. the App...
HelenYang1
by HelenYang1 Occasional Contributor
in Crowdsourcing Questions Last Updated 08-22-2018
0 0
POST
Is it possible to add the ability to print out reports in Crowdsource Manager? Like a print widget in which the end-u...
CarlosReyes2
by CarlosReyes2 Occasional Contributor
in Crowdsourcing Questions Last Updated 07-12-2018
0 0
POST
I am using Citizen Reporter for our community. The link can be found here: http://kimballtwp.maps.arcgis.com/apps/Cro...
RobUsakowski
by RobUsakowski New Contributor
in Crowdsourcing Questions Last Updated 07-11-2018
0 0
POST
Is there a way to require input of certain fields, like a name and/or email field, in a crowdsource reporter app (hos...
AdrianWelsh
by AdrianWelsh MVP Honored Contributor MVP Honored Contributor
0 5
3847
POST
When I use search to locate and zoom to an address the marker icon blocks my ability to click on an existing feature ...
MikeOnzay
by MikeOnzay Frequent Contributor
in Crowdsourcing Questions Last Updated 03-07-2018
0 0
0 Subscribers
