Will it run on Portal?
1835
03-20-2020 07:35 AM
DavidKunz1
I see that it is an AGO hosted solution.  Can it run on Portal or is there a Portal version?
RickeyFight
MVP Alum
David Kunz
We were not able to get it to deploy on our Portal. We had to deploy it to AGOL.
Coronavirus Response | ArcGIS Solutions for Local Government
It says on the solution site:
Solution hosting
  • ArcGIS Online
Maybe this will change when they have more time to work on it?
I believe if you can host it on portal it would say:
Solution hosting
  • ArcGIS Online, or
  • ArcGIS Enterprise 10.4 - 10.8 (Standard or Advanced) with managed data store
RickeyFight
MVP Alum
David Kunz
Solution hosting
  • ArcGIS Online
Solution hosting
  • ArcGIS Online, or
MikeDagle
Rickey is correct. The current version of the Coronavirus Response solution will only work on ArcGIS Online. However, we are currently developing/testing an Enterprise friendly version and it should be released in the near future.
BlytheSpendlove
Hi @MikeDagle is there any way people have been able to get around the whole 'join table not updating as a hosted view' in Enterprise 10.8.1, in order to deploy this solution in that environment? I am aware that this issue is fixed in 10.9 but I am in need of a 10.8.1 solution. Perhaps there's a way to have a script update a layer based on a join?
Blythe Spendlove
