How to use the Share Tool
4789
7
12-13-2023 01:30 PM
About the Share Tool
The share tool is used by Esri staff and Esri Community MVPs to duplicate a message to one or more boards of the same type. For example, posting a question regarding sharing a feature service from ArcGIS Pro to ArcGIS Enterprise, could be created on the ArcGIS Pro questions board and then shared to the ArcGIS Enterprise questions board to provide higher visibility of the question.
How to Share a Message
To share a message, use the following steps:
  1. In a Place or Group, create your question, doc or blog.
    NOTE: Events and Ideas cannot be shared.
  2. Open your published question, doc or blog.
  3. Click the Share Message Button located beneath the title.
  4. A dialog will appear. Expand the nodes and select a target location(s) to which you would like to share. You can share your message up to 5 boards at one time. NodeSelectionTree.jpg
  5. Scroll to the bottom of the dialog and click the Share button.
  6. A thank you note will briefly appear and the dialog will exit.
    NOTE: Labels and tags will not be shared with your message. You will need to go to each target message and add any labels or tags.
  7. Your post is now shared. You will notice a new icon beside the title of your original message indicating that this is a source shared message.source.jpg (notice the direction of the arrow goes to the cloud symbol)
  8. You can go directly to the target posts (those that the source post has been shared to) by clicking the status button located beneath the title.
  9. A dialog will appear indicating the creation and any updates on the message for each board it is being shared to.
  10. Click the link under the Target Message ID to open the target message in a new browser window.
  11. Click OK to exit the dialog.
  12. The target message(s) will show a different icon beside the title indicating that it is from a shared source. target.jpg (notice the direction of the arrow comes from the cloud symbol). Every target message will show the author of the message as a system user named ShareUser. It will also contain a board name from which it was shared and the original author’s name. Below we can see this message was shared from the arcgis-pro-questions board and the Source Author is DaraBurlo.
    NOTE: When a post is shared, all copies of it remain connected so that comments, thread replies, and Accepted Solutions added to any of those copies will sync across the others so that users can build on the same conversation from multiple locations. Syncing occurs on a 24 hour cycle.
Comments
EdCarter
Is this document supposed to be in a different format? It would help if it was reviewed by someone who doesn't know the process already so that clarity can be assured.
About the Share Tool How to Share a Message About the Share Tool The share tool is used by Esri staff and Esri Community MVPs to duplicate a message to one or more boards of the same type. For example, posting a question regarding sharing a feature service from ArcGIS Pro to ArcGIS Enterprise, could be created on the ArcGIS Pro questions board and then shared to the ArcGIS Enterprise questions board to provide higher visibility of the question. How to Share a Message To share a message, use the following steps: In a Place or Group, create your question, doc or blog. NOTE: Events and Ideas cannot be shared. Open your published question, doc or blog. Click the Share Message Button located beneath the title. A dialog will appear. Expand the nodes and select a target location(s) to which you would like to share. You can share your message up to 5 boards at one time. Scroll to the bottom of the dialog and click the Share button. A thank you note will briefly appear and the dialog will exit. NOTE: Labels and tags will not be shared with your message. You will need to go to each target message and add any labels or tags. Your post is now shared. You will notice a new icon beside the title of your original message indicating that this is a source shared message. (notice the direction of the arrow goes to the cloud symbol) You can go directly to the target posts (those that the source post has been shared to) by clicking the status button located beneath the title. A dialog will appear indicating the creation and any updates on the message for each board it is being shared to. Click the link under the Target Message ID to open the target message in a new browser window. Click OK to exit the dialog. The target message(s) will show a different icon beside the title indicating that it is from a shared source. (notice the direction of the arrow comes from the cloud symbol). Every target message will show the author of the message as a system user named ShareUser. It will also contain a board name from which it was shared and the original author's name. Below we can see this message was shared from the arcgis-pro-questions board and the Source Author is DaraBurlo. NOTE: When a post is shared, all copies of it remain connected so that comments, thread replies, and Accepted Solutions added to any of those copies will sync across the others so that users can build on the same conversation from multiple locations. Syncing occurs on a 24 hour cycle.
JesseCloutier
Esri Community Manager
@EdCarter, are you seeing this page without any formatting, including no paragraphs, numbering, or images? We want to make sure we understand the block of copy-pasted text from the article to your comment, which doesn't reflect how this How To article is set up or what we're seeing on our end. Thanks for clarifying.
EdCarter
Hi Jessie,
Yes, it looks like this on my outlook:
[cid:[email protected]]
JesseCloutier
Thanks for clarifying that it's an Outlook email that you're referring to, @EdCarter. Though the image you tried to upload isn't displaying correctly, I can confirm that email notifications from Esri Community do not support most formatting. Instead, we recommend treating those emails more as awareness that there's been an update to a post, Board, or Place that you're subscribed to in Esri Community and visit it within our platform to view the new content as it's meant to be displayed. Hope this helps!
imanebenromdhane
Merci pour vos recommandations et je vais les suivre
Mara
by Esri Contributor
Hello!
Does anyone know how I can move the original post (source) to the same community that the shared post (target) is in? I'm afraid if I hit Move on the original, both articles will then exist side by side in the target community, because I can't find a way to delete a "share" post (the target).
Another option might be to delete the source post altogether, but then I'm not sure if links in the "share" post (target) will be broken.
Thanks!
JesseCloutier
@Mara, in the situation you're describing it would most likely be best to move the original post to the location you want it in, then our team can archive the shared version of that same post. One thing we'll want to look at is whether some original comments on the shared post should be moved over to the original as well. I'll reach out to you offline to figure out what's needed and assist.
Version history
Last update:
‎12-13-2023 10:12 AM
Updated by:
Contributors
