color coding?
974
04-19-2018 11:33 AM
MasonJobe
New Contributor II
how if I have the shapefile off all us counties added to my TOC and all the shapes of the states, could I go in and individually change the color of each county to display the data I have collected?
Tags (1)
DanPatterson_Retired
You are looking for Symbology and particularly  Color Ramp
Perhaps a Unique color ramp
http://pro.arcgis.com/en/pro-app/help/mapping/layer-properties/unique-value.htm
This is from Pro's help... an identical topic exists for arcmap.
Basics of symbology are located within the same area
MasonJobe
New Contributor II
The only problem I have then, It does this for every county in the U.S. or whatever I have selected by attribute, not the specific county I am clicking on.
Best,
Mason B
If you chose unique values, they would all get a unique color.  If you want a particular color for each one, then you would have to do it manually.  So reading a bit of some of the tutorials would help.
How to symbolize maps for instance http://pro.arcgis.com/en/pro-app/get-started/symbolize-your-data.htm
MasonJobe
New Contributor II
Any Idea how I can select just one county and Change its color?
by Anonymous User
Not applicable
Hello Mason,
Are you using Business or Community analyst web application? Could you please provide me with "steps to reproduce".
Thanks.
