Good evening Rupert-
Good to hear from you! Years ago, you helped me with a swipe map issue.
I tried removing the 2 hyper links, contained in the "name" section of the caption, but it still does not save. image 54 had one, as well as 62.
I think the error message that the hyper link people had, was an issue of quotes not being in the correct place on the link? I think mine were.... but still, with the links totally removed, the maptour does not save the "corrections".
I really really think the issue is somehow related to permissions on that map tour points layer, where-ever it is stored.
Thanks for suggestions- I am still open for more!
Sincerely,
Bob W
AND...
HI again Rupert-
I created the map... with tracks. Then, used the maptour wizard to "build" the photos in, which were stored in flikr. This , of course, creates the maptour points layer... in the webmap. Right?
Last week... I WAS even able to "import" a few more images into that maptour, and all went well.
However, yesterday, after making some adjustments to 6 other images, I tried to import THOSE into the maptour, and was unsuccessful. "unable to save" message, but not clear why. Also, I was unable to edit the captions on the existing images. For instance, I was unable to change that "revolutionary square" thing to "plaza de la revolucion" which I had wanted to do.
I WAS able to change the captions, but going back to that original webmap, finding the points layer... enabling editing... and then going into the table, and manually changing the table... and saving the map.
But I was still NOT able to change or edit, or import 6 more images, using the "builder mode".
I would still like to add the 6. Actually... I CAN import the 6 new images... But after that import, it will not save.
I tried different browsers, different computers... nothing works- I can not edit, nor add to that existing map tour points layer, except by manually editing in the original map.
Sincerely,
Bob W
