Story Maps-Disable Login Prompt
846
10-18-2017 04:21 AM
JamesFitzgerald3
Hello, I downloaded the story map template from GitHub. Is there a way to disable the login prompt. I want my organization to be able to view the story map but not have to create a AGOL account.  The template is located on my server. Any help is appreciated!!
Tags (1)
RupertEssinger
Esri Alum
Hi James
So in this case, the Story Map hosted in ArcGIS Online isn't/won't be shared publicly right? (If it is shared publicly, your users wouldn't need an ArcGIS Online account to view your story via your customized code).
Rupert
JamesFitzgerald3
Rupert,
I have developed a web application where the user needs to see the story map. I have downloaded the story map from GitHub and placed the code on my server.  I cannot share it publicly. The user will not have a AGOL account. The user only accesses the story map through the web application I have created. I need to overwrite the login proxy to story map. I have read developers editing the config.JS file and index.html file by creating a proxy. Thanks
