Link descriptions not working in Series
2382
07-30-2015 09:59 AM
BillSpiking__GISP
Hi Gregory,
I'm having an issue with link descriptions not working in the side accordion and tabbed themed story maps.  They work fine in the story map tour.  Have you seen this issue before?
Thank you,
Bill
GregoryL_Azou
Ok cool. Got you, yes you can do that. Highlight some text and then click the link button.
The link will reuse your text
BillSpiking__GISP
They work in this example...
http://mediamaps.esri.com/2014-olympics-team-usa/
Not sure what I'm doing wrong.
GregoryL_Azou
Are you using Story Map Series, see Story Map Series | Story Maps, the link you is a deprecated template that was called Side Accordion. Story Map Series now integrate a Side Accordion layout.
To edit your description, unlike Map Tour, you will have a little text editor that will let you create link interactively. So you don't have to know about HTML, you will do everything in there.
All the capabilities of the deprecated Side Accordion are in Story Map Series.
Hope this will work for you
BillSpiking__GISP
Yep, I'm using the Story Map Series.  The link above was just an example of how I'd like to implement a link description.  The text editor in the Story Map Series allows you to add a link, but no description for the link.  All other AGO products allow the user to add a link description....not sure why this one does not.
Thank you sir,
Bill
GregoryL_Azou
BillSpiking__GISP
Hahaha!  That's too easy.....
Thank you Gregory!
