From where to get ESRI Bump Map Tools?
1002
08-16-2017 02:32 AM
NasirHameed
I am intending to download ESRI Bump Map Tools from the provided link referred below;
https://blogs.esri.com/esri/arcgis/2010/01/21/introducing-the-arcgis-bump-map-tools/#comment-12482
But, didn't found any working link from where I can download these tools. I will be highly appreciable if anybody could let me know the download link and also enlighten me whether these tools can be used with ArcGIS 10.5 installed on my system?
DanPatterson_Retired
That is quite old and doesn't appear on the code sharing site, so it isn't supported now
There are a few links for similar tools for imagery ... bump-i-fied imagery...  and alternate options if using terrain data
NasirHameed
I recently visited the post and found that download link has been reactivated by the author. Now these incredible tools are ready to be explored. Great news.
Introducing the ArcGIS bump map tools | ArcGIS Blog
check the discussion at the bottom, there were written for 9.x and might work in 10.x,
so some work might be necessary, but definitely doeable.
