drone symbol
6188
10-30-2017 03:48 PM
Will
Anyone know of a good drone/UAV/quadcopter point symbol I can use in ArcMap?
XanderBakker
Esri Esteemed Contributor
In ArcMap you can use images as symbols. When you Google for "Drone icon" you get a lot of hits and will probably find something that can be used for your specific purpose:
XanderBakker
AdrianWelsh
MVP Honored Contributor
William (Will) Patterson
I know this is an old thread but I search for SVG file types and came up with this one:
drone float
But I can't copy and paste an SVG here (don't use the one above). Go to this link:
https://svgsilh.com/image/2025680.html
And click on Download SVG.
In ArcGIS Pro, under the symbology for a point feature, under the layers tab, drop down the list to "Shape marker". Then click on File to find the SVG file. From here you can choose this drone svg and manipulate the size and color, etc.
NicholasFranchino
Maybe an old thread...but this is what I was looking for today.  I found the one mentioned above, followed the instructions and it worked great.
Then I found a few more icons.  I really like this one:  https://www.flaticon.com/free-icon/drone_1812583?term=drone&page=1&position=35  (just need to give them attribution)
simple drone icon
Also, if you can't find an SVG you like...just get a PNG and then do a PNG to SVG converter.  I found that it works as well.
