Is there a workflow for looping through .pagx files in order to standardize the map templates by accessing certain elements?
832
07-31-2020 12:22 PM
HannahDean
I think this is a separate issue from the ones I've found open regarding layouts - but apologies if this query already exists.
I am looking to batch edit via Python a set of pagx files - but I'm not finding any samples or instructions on this.  For example, I'd like to point to a folder, and add a certain north arrow to all the .pagx template files in that folder.  Is this kind of workflow documented somewhere?
I found a good page on looping through elements in an mxd - i.e. arcpy.mapping days - arcpy - Creating Loop to replace text in page layout in multiple MXDs instead of one MXD at a time? ...
However, I am now trying to instead loop through a set of pagx files - or is the best method to simply open up all those pagx files into an aprx file and then batch edit that way?
