Using calcite with React: "could not fetch component message bundle"
2598
7
04-18-2023 02:46 PM
sccwrp
Hi there,
I'm running into trouble using a lot of the components with React. Imports all work fine, but when I try to use some components (for instance, CalciteButton) in my app, I receive an error message that says:
Error: could not fetch component message bundle
I've cloned the example React repo from GitHub and all components work fine, but I can't figure out what I'm doing wrong.
Thanks!
KittyHurley
@sccwrp It looks like the index.js's setAssetPath isn't set for the distribution build.
An updated CodeSandbox and example set on CDN, but local hosted assets could also be used:
setAssetPath("https://js.arcgis.com/calcite-components/1.2.0/assets");
LefterisKoumis
Without seeing your code, I don't know what you already have.
Is your import like this?
import "@esri/calcite-components/dist/components/calcite-button";
import "@esri/calcite-components/dist/calcite/calcite.css";
and your file structure like this:
KittyHurley
@sccwrp Would you be able to put together an example with CodeSandbox?
There are a few gotchas related to React, documented on the Framework integration page, if its a helpful resource for getting started with Calcite and React.
sccwrp
@KittyHurley @LefterisKoumis
Here is a CodeSandbox of a barebones react-redux app attempting to use calcite components
It's getting that same "could not fetch component message bundle" error
KittyHurley
sccwrp
I see, thank you!
DavidWilton
I was getting this issue with angular. Just in case anyone else gets it I will post my solution as this is the first google hit. The cause is if you are using routing you need to set the path without the route
import { setAssetPath } from '@esri/calcite-components/dist/components';
setAssetPath(window.location.origin);
albert_ssp
Where are you placing these lines? In the router module?
