Map doesn't show in browser using map components, calcite components with Angular.
302
03-27-2025 01:20 PM
ForrestLin
I'm working on website using map components, calcite components with Angular.
I create a angular component "esri-map" with arcgis-map
esri-map.component.html:
 <arcgis-map item-id="cece49703cc24b0783dffb3032b0679c"></arcgis-map>
I put it in <calcite-shell>:
app.component.html:
<calcite-shell>
    <app-esri-map ></app-esri-map>
 </calcite-shell>
The map doesn't show in browser.
 I inspect the document:
The map component <arcgis-map> is suspended.
ForrestLin
Issue is resolved:
`<app-esri-map>` element needs a height and width in css:
app-esri-map {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
ForrestLin
Issue is resolved:
app-esri-map {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
