How to create a calcite button that looks like a link?
@ForrestLin You can use CSS to fit your use case, perhaps something like: https://codepen.io/geospatialem/pen/gONOLVG
<style> calcite-button[href] { --calcite-color-brand: var(--calcite-color-text-link); text-decoration: underline solid var(--calcite-color-text-link); } </style> <calcite-button appearance="transparent" href="https://developers.arcgis.com/calcite-design-system/components/button">Button with a link</calcite-button> <calcite-button>Button with no link</calcite-button>
@ACrateau Yes, you can do so using the --calcite-font-size-relative-base and --calcite-font-weight-normal (deprecated) tokens: https://codepen.io/geospatialem/pen/ZYpayqW.
#custom-btn { --calcite-font-size-relative-base: var(--calcite-font-size-relative-lg); /* Note that --calcite-font-weight-normal is deprecated, but still supported in Button */ --calcite-font-weight-normal: var(--calcite-font-weight-bold); }
While --calcite-font-weight-normal is supported it is deprecated, but the team is working on support for the replacement --calcite-font-weight-regular token soon. Additional information can be sought and followed via issue #14190.
@KittyHurley Is it possible to use the same logic to increase the default font size and weight of a button's text? I'm trying the same approach you provided here and adding the CSS properties font-weight and font-size, but the renderer is ignoring them - any thoughts?
@KittyHurley
Thank you!
