get combobox selected display
1961
05-23-2023 03:05 PM
LefterisKoumis
I have this simple calcite combobox. I want to capture the selected display,not its value.
It is simple to get the value.
So, if I select the first option how do I capture "One", the text-label value?
https://codepen.io/lkoumis1/pen/mdzvBKv?editors=1111
<link rel="stylesheet" href="https://unpkg.com/@esri/calcite-components/dist/calcite/calcite.css" />
<script src="https://unpkg.com/@esri/calcite-components/dist/calcite/calcite.esm.js" type="module"></script>
<calcite-combobox id="test">
  <calcite-combobox-item value="1" text-label="One"></calcite-combobox-item>
  <calcite-combobox-item selected value="2" text-label="Two"></calcite-combobox-item>
</calcite-combobox>
document
  .getElementById("test").addEventListener("calciteComboboxChange", function (event) {
  console.log(document.getElementById("test").value)
KittyHurley
@LefterisKoumis Depending on the intent, you can use JavaScript, for instance:
Loop through selected items:
document.getElementById("test").addEventListener("calciteComboboxChange", (evt) => {
    for (item of evt.target.selectedItems) {
      console.log(item.textLabel);
Gather the latest selected item:
  const selectedItemNumber = evt.target.selectedItems.length - 1;
  console.log(evt.target.selectedItems[selectedItemNumber]?.textLabel);
KittyHurley
