Can calcite been self-hosted and been referenced by inlucde mode?
515
12-13-2024 01:00 AM
baohuachu7
I's coding in traditional mode by reference the css and js files. Can calcite been hosted locally on my server?
DitwanDPrice
Hey, you should be able to get the files locally by either visiting the calcite repository or getting them from npm. I believe once downloaded you could then place the files you need on your server and reference them in your project.
You also might need to use `setAssetPath` as described here to make sure you are referencing the correct location that you have the files stored.
baohuachu7
The process to deploy the resources locally  is as the steps below?
  • in powershell to execute : npm install @esri/calcite-components
  • locate the resources under the installed "node_modules" directory. For example tis is under "D:\workspace\devWorkspace\node_modules\.store\@esri+calcite-components@2.13.2\node_modules\@esri\calcite-components\dist\calcite"
  • copy the files in the directory and deploy to the static resources web server.
